Well, I just got the bad news from the mechanic at the marina. He tells me I have one cylinder with no compression and I need a new powerhead. I never used this mechanic before and he seemed a little quick to determine I needed a power head. I have searched this forum in length and all suggests you need to pull the head to check head gasket. I brought boat home and did a compression test on my own to find
Port side top Cylinder 90#
Port side 110#
Starboard top 70#
Starboard bottom 110#
Do I have 2 bad cylinders? What should be my next step? Should I pull the heads on both sides or starboard or just give up on this one??
Port side 110#
Starboard top 70#
