Greetings from the Jungle, I'm looking for specs on Vertical Shaft lengths.There aren't parts available here,but there is a good machine shop. We need to shorten a long shaft for use in a short Honda Bf 15. Is the 5 inch difference close enough or is there an actual spec available somewhere for the shaft dimension. I've come up with 604 mm ,Maybe simpler,Does anyone have a short shaft available to give me a length? Any Ideas?? Thnx,JD
