Minn Kota RipTide Problem
FloridaSon
I have RT55 unit and I bought it new about 5 years ago. I have only used it a few times a year and now it's not working. When I turn it on at the handle the prop started to turn slightly but stopped and it just makes a funny rattling noise inside the handle area. Battery has full charge. Is this something I can fix or does it require a service tech? Thank you :redface:
snookcrazy
Re: Minn Kota RipTide Problem
if you didn't already fix it order a new switch, if its a hand control model just 20.00, that probably is it. Not much to the HC model just a motor and a switch, thats why I went with that model.
