  #1
Old January 24th, 2004, 04:46 PM
algee algee is offline
Default Paint on Aluminum Bracket
I have an engine mounting bracket with some small chips starting to flake off. Paint has seperated or bubbled away from the aluminum in a small area. I can see, in another area, where in the past this happened & was painted over. Has anybody out there had any luck "touching up" areas like this? What should I use? Thanks in advance, AL
  #2
Old January 24th, 2004, 04:53 PM
Drowned Rat's Avatar
Drowned Rat Drowned Rat is online now
Default Re: Paint on Aluminum Bracket
Hi algee. You need to feather the bad paint off with sandpaper. Get the big pieces off with a scrapper, then sand down the rest until you can't feel any ridges where the metal is exposed. Prime with zinc oxide and then paint.
__________________
“We do not inherit the earth from our fathers, we are borrowing it from our children.”
  #3
Old January 25th, 2004, 06:42 AM
ThomWV ThomWV is offline
Mine was doing the same thing. I had pulled it off to paint the boat and give the boat a new engine and so I figgured it was time to do something about it. Mine had been flaking for a year or two. Its a bracket by Gil and the paint that was used on it was probably a 2-part epoxy, very thick.I had the bracket sand blasted and then immediately painted it with zinc chromate primer. It is my understanding that you must prime aluminum within about 4 hours of either sanding or blasting or aluminum oxide begins (obviously it begins immediately but 4 hours is OK from what I've read) to form and once that's happened no succeeding coats will hold.Anyway I had it sand blasted and primed it. I then followed that green zinc chromate with two coats of Awl Grip 545 white primer and that's where it stands right now. I haven't gone any farther with it because I don't know what color I want it to be. I could just use the same paint that is going on the hull (an off white Awl Grip) or I might paint it back to close to its original medium gray color, or maybe I'll paint it to match the deep charcoal gray of the new engine. Just not sure. For finish coats if I decide to match the hull I'll just use the same paint for it (Awl Grip) but if I go with some other color I'll probably just take it to an auto body shop and have them shoot it in Imron.Thom
  #4
Old January 25th, 2004, 09:11 AM
18rabbit 18rabbit is offline
Algee - After cleaning off the old stuff, you should prime the bare aluminum with zinc chromate primer. As far as we are concerned, the only difference between the yellow and the green is color. (Technically, the yellow primer is less resistive to electrical current, but to a degree that doesn’t matter to much of anything.) Often a ‘normal’ primer is applied to the zinc chromate, but it is not necessary. Thom’s 2 coats of white primer will hide the ‘green’ and allow him to paint the final coat any color he wants.In a spray can, zinc chromate goes for as much as $16 at marinas. The exact same primer (Tempo brand/12-oz can) is available from aircraft supply places for as little as $3.50/can. Also available online. I have only seen one other brand, same primer but costs even more.Zinc chromate is high on someone’s “we’re scared of this stuff” list and was removed from a lot of primers. It is still the best sacrificial primer for aluminum parts and as such it is still used in the aircraft and marine industries.
  #5
Old January 26th, 2004, 02:25 AM
SeaDawg SeaDawg is offline
My friend just had his bracket powder painted (it was off of a 1987 Grady White Offshore 24), just before he put a 225 Yammy 4-stoke on it.It looks great, and should hold up a long time.He took it to a car shop that powder paints car frames.
  #6
Old January 29th, 2004, 05:00 PM
Thanks All, Zinc Chromate primer It is. I hope I can do a small area, do not want to remove the engine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
What material to bed an aluminum kicker bracket? Trophy24 Boat Restoration and Building 3 March 9th, 2007 08:55 AM
aluminum paint RyBisp Boat Restoration and Building 4 October 3rd, 2006 08:25 AM
Gluing transducer bracket to aluminum transom NBE Electrics, Electronics and Trolling Motors 2 June 4th, 2006 12:31 AM
bottom paint on outboard bracket??? angus63 Johnson & Evinrude Outboards 8 May 11th, 2003 08:28 AM
What best paint and primer to paint an aluminum out drive John Smith Boat Restoration and Building 3 January 22nd, 2003 04:51 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
