Andy Fogle
- Oct 8, 2010
- 4
I have a 1997 Volvo Penta 3.0 l engine. The engine was ran hot when a belt broke while at full throttle. I checked the compression and it was good on all four cylinders (150 - 160 psi). I was getting milky oil in the crankcase, so I figured I had cracked the head. I pulled the head and sure enough, it was cracked. The head was repaired and pressure tested, then I re-installed the head.
After changing the oil and filter and installing the head, I ran the engine for about 15 minutes. The engine ran great, but then I pulled the dipstick and saw milky oil again. I changed the oil and filter again and ran the engine for about 5 minutes and the oil was starting to get milky again.
I pulled the boat back in the garage and returned to it a few days later. I turned the engine over a few times and pulled the spark plugs - there were water droplets on three of the four plugs.
I suspect a cracked block, but I want to know if there is anything else that it could be before I pull the engine. Could it be the manifold? Any suggestions would be appreciated.
