So i finally had the motor running fine in the yard on muffs took it to the lake this morning to run things out and get a feel for it on water and it wouldn't stay running long enough to get it off of the trailer, i could mess with the choke enough to get it running for maybe 30sec and then it would just crap out. I swapped plugs as i had an extra set in the kit i put in the boat and even swapped the fuel line and primer bulb as they were about 13 years old and way passed hard. discovered a needle was stuck on the bottom carb and got it fixed but still no go i get fuel to all of the carbs as i can take the drain screws out and once the gas drains prime it again and more comes out choking or not choking didn't seem to matter except the 1 time i had it running for about 30sec but it came to the same result. And another q i have has something to do with the reed valves i believe while the motor was in the water air would be rushing out of the carbs and i could hear it hissing it had to have been the air rushing back into the exhaust and pushing the air through because it would only do it for maybe a min or 2 and then after trying to get it running it would do it again so could i have a stuck reed?
