Re: 87 yamaha 150 pro-v
I have removed the carburetors several times when the engine was running poorly. Mostly to remove water. I have had several issues with water getting though the filter on the side of the engine. This year I installed a water separator filter.
If you use the choke and the engine starts, then when you let the choke off the engine quits you may have a fuel blockage some where.
There are several master mechanics in this forum, hopefully you can get one of them to respond.
