I have a 1982 Evinrude 115. The rectifier has fried. (see photo). The one that fried appears to be a high amp model mounted on top of the engine block halfway under the flywheel. I think i has a high amp type because the motor has tilt and trim? Anyway, the tilt and trim doesn't even work. My questions are:
1) Can I replace the high amp regulator/rectifier with a typical 10amp type off of a 1979 Evinrude 115 parts motor I have? It is the round type that is bolted next to the terminal block - see photo
2) The purpose of the rectifier /regulator is to charge the battery? Is that correct?
Any other advice for this small project would be appreciated.
Thanks in advance
Thanks in advance
