Re: Carburetor question
If the carbs on the 175 are also WH-## then yes. However you would first have to change the jets, as the jets from the 150 are not the same as the ones the 175 needs.
***Warning***
The carb jet sizing goes with the carb model, not the engine. The carbs, though they look the same, are different in a lot of ways.
If you move carbs between engine sizes, there will be a tradeoff. In this case, you'll probably give up a bit of hole shot for a bit of top end, if you gain anything at all.
Also, the jetting will not be just right, and you'll have to do some testing and piston top and plug reading to dial it in.
2 cycle fuel and air flow is a whole matrix of parameters approaching magic.
hope it helps
John
