Re: Help!!! Magnet broke off the drain plug!
First off, all magnets have a north and south pole. If 2 magnets are positioned near one another, the alike poles will repel and the opposite poles will attract. Magnets will not "stick" to aluminum, brass, copper, lead, berillium, indium, titanium or a good quality stainless steel.<br /><br />I'd cut a coat hanger and "fish" it through the drain plug hole for the magnet. If it's laying on something non-magnetic like the outdrive housing, it will attach itself to the coat hanger if you should touch the magnet with the coat hanger. Then you can retract it though the drain plug hole.<br /><br />If I didn't find the magnet, I'd at least put the outdrive in gear and turn it by hand to make sure the magnet wasn't in one of the gear teeth where it could cause problems. If that was OK, stick another magnetic drain plug in it and see what you find next time you drain the gearlube.<br /><br />If the outdrive binds up/jams while you are turning it by hand, I don't know anything you could do other than tear the outdrive down.<br /><br />Maybe, somebody else will have a better idea.
