superman111
- Sep 18, 2010
- 27
I recently got a boat, the guy said that it was jumping when put into gear, i didnt worry bout this much because i thought i knew what it was, well got out on the lake and it went good first two or three times but really was jumping quite a bit, I got my father out there with me and hit it wide open, went good, but was still jumping then it came outa gear, engine revved as high as i have ever heard then kicked into gear, snapped motor mounts, knocked hole in boat, never seen a motor jump out of the water so high, then motor sank. We got the motor back up in the boat and was towed in, took it apart almost immediatly after getting home,
I figured the forward gear was getting the ears rounded out, turns out that the forward gear is like brand new? as a matter of a fact all three gears are like that, He said he replaced one of them , but I was unable to tell which one as none of them had any signs of wear. everythng looked good? so i put it back together, welded up mounts, went back to the lake, still same thing, any ideas? the shift cable is ajusted correctly too, checked that b4 I bought it.
