superman111
- Sep 18, 2010
- 27
What is the compression on a evinrude 18 supposed to be? The person i got mine from said it ran fine, just needed a pull rope. put one on it and it wont crank for anything, he said the carb just got cleaned out, and that it had a new water pump put on it, I checked both out and that is correct, Idk why he would go through having a shop put this on if the motor wouldnt run in the first place? It has good spark the only other thing i can see is the compression seems awfully low, approximately 65-75, dont think it will ever run this low, But idk what the compression rating is for a engine this old? If it does have to be rebuilt then i have a few more questions. Thanks Caleb
