Re: alpha1 gen1 transom
I stand corrected that there is 8 bolts instead of 6 . Thanks Doc you were right .
The last 2 were under the tiller arm cut out , the casting rib covers them on the inner transom. Once those were removed the sheild was loose, came right off .
To support the weight and not let the inner plate shift ,I left it bolted to the bellhousing . cut 2x4's at the same angle of the hull and made 2 wedge blocks . they looked like doorstops but bigger. I put them in the foor under my floor jack and placed the boards under the jacks frame to let the wheels hang over for clearance. the boards are to keep the jack level on the angle. There was just enough room under the motor for the small flor jack to reach the corner of the bellhousing solid enough to lift the engine slighly. Then when I removed the lower zinc bolts , I placed a pin the same size from the back inside the inner transom. Also I left the 2 long bolts in the hull but loose from the transom sheild ,just to help the transom stay still.
Now all I have to do is get it back on right ! HAAAA HAAAA!
Hopefully they will fallback on with cables , hoses and harnesses going to there right spots thru the hull. Like an octopuss eating a shellfish from outside a jar , feeling their ways to were they are supposed to be. Hahaa
I will find out tommorow. Thank you for the advice guys I will keep you posted .
My friend made a movie of it with his droid phone but cant post it just yet.
I would like to say this site is great ! If somebody knew nothing about boating they could learn alot right here.
