pilotbret37
- Sep 30, 2010
- 2
My motor will crank, idle, and come out of the gate strong. But in about 200 yards, it sounds like it is starving for fuel. My primer was old, so I replaced it and primer still will not stay pumped up. Is this a problem with the tank, the new line, or a fuel pump. In the yard it will crank, idle and run, but will idle low until i pump on the primer, then it will idle on up to normal, but then down again.
