Hello to everyone,
I have a question for you all. My brother has a 1995 Chevrolet Silverado 4X4 Extended cab pickup truck and the tranny has started to act up today. Basically it has worked good up to now and it will not shift out of 2nd gear and after it seems to be reving up in neutral when out of second gear and it will not go into reverse at all either. It has 225,000 miles on the odometer. We are thinking a transmission rebuild is in order or go ahead and order a re-manufactured transmission, but we want to make sure it isn;t anything else simple that could be a cheap fix. He also checked the transmission fluid and it looked cleaned and had no burnt smell to it. What are your ideals suggestions? Thanks again for all of your help.
