BluefishBoy
- Aug 1, 2010
- 21
OK, first of all several months ago, check engine light came on. I posted all symptoms on here (no powerloss, just a constant alarm sounding). replaced the water seperating filters and the spark plugs and all ran fine for a few trips.
NEW PROBLEM
I was out on the LIS recently in 4-6 footers. Nothing too hard but it was rough and several times waves came over the bow.
About 5 miles into a 15 mile jog my check engine light came on while at about 4200 rpm, Major power loss and sputtering. Boat seemed to buck and jump if i tried to accelerate, but ran fine at idle speed both in and out of gear, reverse too.
was able to idle back towards shore (not an easy endeavor in 4-6 foot seas). let the engine sit for a few while we fished and it fired right back up. Was able to get back up on plane for about 1/2 mile and then same symptom.
Decided it would be better to head in so at idle speed headed back in to the marina. When I approached the beginnings of the no wake zone i tried to throttle back only to realize that i was either in gear or out, no throttle control even tho the linkage was tight. Same results in reverse.
Through the stares and swears of all the people yelling at me and screaming NO WAKE at me I managed to get into the boat ramp and trailer the boat.
Linkage is tight, Plenty of fluid, Starts on command, runs great out of the water, new plugs and filters (Gapped and indexed)
Stuck throttle
bucking engine
powerloss at alarm sounding
Any ideas?
NEW PROBLEM
Stuck throttle
bucking engine
Any ideas?
