1976 24 Searay 351 Mercruiser 233 hp<br /><br />I'm wondering which is the best way to determine what's causing a slight howling/scraping type noise - I swear - I'm begining to hear comming from the backside of my 351? when idling the engine.<br /><br />I'm thinking, remove the belt first to rule out pully, water pump noises traveling 'thru' the engine to the rear?<br /><br />Or remove the outdrive / start her up, and see if the noise is still there and IF I DO GO THIS ROUTE, can I run this engine with outdrive REMOVED, and no water hooked up for a few minutes or so just to see if the noise is still present?<br /><br />Thanks,<br />PB
