I am ready to wire up the switch plate cable from the motor on my 1956 25526 Lark 30. I have the relay box that came with it. I spent $67 on a manual and it is useless as the very skimpy addendum section specific to this motor shows a different wiring set up. Mine has 8 wires in the cable, manual shows 4. The motor cable plugs into a nylon plug to the cable for the switch plate. I have in the cable to the switches (all I am going to use is a push button for the choke and an off/on/start key ignition switch):
1 larger ga. (10?) solid green wire (that wire goes to the side of the sol. that the pos. battery cable goes to.
1 larger ga. (10?) that is solid brown (that wire looks like it is unused in the sol. box.
1 red with a white stripe (16 ga for the rest listed?)
1 solid white
1 solid gray
1 solid black
1 black with white stripe
1 light tan solid
Anyone have any ideas on which are used for the starter and which for the choke?
1 solid white
1 solid gray
1 solid black
1 light tan solid
