Power Pack or Jump Pack Suggestions
MyOldBoat
I am looking into buying a jumpstarter pack to put on the boat for the piece of mind of being able to jump the battery just in case.
I know several boats carry these and I am curious to hear what brands and models people are using and their luck with them. I have used one similar to this one: http://www.amazon.com/Wagan-EL2464-200-Watt-Power-Starter/dp/B001TZWE1S
Any suggestions to what you use, or have experience with is greatly appreciated!
rwidman
Re: Power Pack or Jump Pack Suggestions
Why not just have a dual battery system installed in the boat? It serves the same purpose, but adds a lot more such as extra power to run electronics and lighting.
Silvertip
I've owned three of these of varying quality and will not own another one. They simply do not last. As suggested, install a dual battery swtich system and have a very versatile system.
MyOldBoat
Thanks for the suggestions. I think I will follow your advice and install a dual battery system.
Ideally, I would like to buy the BEP VSR battery switch that charges the primary battery and ounce it reaches full charge it charges the secondary battery. Here is the switch I am looking at: http://www.bepmarine.com/home-mainmenu-8/product-273/714-100a-single-engine-two-battery-banks
My question on this is, is this overkill and can I do something more basic? Maybe I am just being cheap and not wanting to pay over a $100 just on the switch alone. Is this the type of system you are running? Is this what you recommend?
Thanks again!
jhebert
Ensign
"Power pack" is a bad name to use for a battery intended for giving jump-starts. In marine jargon a "power pack" is an electronic ignition module in OMC engines.
Silvertip
How you implement a dual battery system depends on how you feel about a dual battery switch and if you understand what happens when you have the switch set to OFF, BAT 1, BAT 2 or BOTH. If that is unclear or you feel uncomfortable, then you need a VSR or similar system which is automatic. The most versatile system is the dual battery switch. The most automatic is a VSR. The cheapest is a dual battery switch with the VSR being more expensive.
brad614
I run a nationwide emergency roadside service, and we do approximately 1000 automotive jumpstarts PER WEEK! Obviously, we have tested and gone through almost every jump pack there is on the market, and now only buy one. It is a "Solar ES5000". They also make an ES2500 which has slightly less CCA, but I would highly recommend these units. They are a bit pricey (up to $150) but you get what you pay for. I have one in my personal truck. It sat for over a year without being charged, and then fired my completely dead Ford F-350 with a 460 cid gas engine without a problem.
