Re: loss of thrust
So it won't have a drive pin then, it's a splined shaft and a through prop exhaust hub. When you put it in forward you should be able to free spin it in one direction, when you go in the opposite direction it should lock up inside the gearcase, if you continue to apply pressure the flywheel should start to turn. As OptsyEagle stated, a spun hub can troll, it's only evident when going over quarter/half throttle, the RPM's will climb higher than what the engine should perform at during regular operation, it's an "overrev" condition. In the center of the through hub exhaust is a splined insert which is surrounded by rubber which is pressed into a hub and then i'm assuming is somehow glued to the metal. When you hit a rock or stump, instead of a shear pin breaking the rubber inside the prop will break away from the prop housing. Once this happens it's known as a "spun hub" as it cannot take the torque of the motor at high speed operation. This is my explaination, if it's wrong someone will correct me but it's my undertanding on how things work. There is a bushing listed for the prop but I'd imagine this has to be installed by a prop shop with a press and all the proper tools.
