eclark53520
- Sep 2, 2010
- 174
I did a compression check earlier this week.
I warmed the engine up on the muffs at idle.
Then i turned the water supply off because i didn't want to get all wet while i took out the plugs and readied the engine for the compression check.
I never turned the water on while i turned over the engine 6 times for approx 4 secs each time to test the compression. Which btw, was 120psi on all three cylinders!
Did i destroy my impeller? Since i don't have a tell tale(70el77s), how can i check(beyond installing a tell tale, which i will do later) that my impeller is good?
