I have 1989 johnson 9.9hp. I completly rebuilt the lower unit with all seals o-rings gasket etc. new water pump. as it was leaking oil out the prop exhaust. Or I noticed oil mixed with water in the prop.
I even replaced the seals twice as i had trouble the first time, went and bout a manual and had no problems doing the complete rebuild the second time.
Its is still doing it after rebuilding. Would there be a warped part ot casting in there?
Thanks
Thanks
