jerryjerry05
- May 7, 2008
- 17,927
200 hp 2003 Optimax.
The oil warning beeper goes off about every 5 min.It's full of oil in the motor tank and almost full in the boat tank.It will pump from the main tank into the smaller tank.
The dash guage says it at 91% capacity when it beeps.
The motor runs great.The owner had capsized about 6 mo ago in salt water.But says the guages are new.
I have removed the sender in the main tank and tried to make it do anything on the guage.Unhooking the wire sends a signal that something is wrong.I removed the sender and lifted the float up and down,NOTHING no difference.I remove the oil in the motor tank and still no changes in the guage.It's a new sender in the small tank.
Any Ideas?????????????? Thanks,J
