stickerhill
- Aug 31, 2010
- 6
I have a 80 hp mercury that I just bought in June. It needed a lot of TLC when I bought it. It had to be started with starting fluid when I got it. I have since overhauled the carbs, installed new hoses from the tank to the carbs, new primer bulb. After doing the carbs it would start fine and restart all day long but the idle was 1400 rpm and would die if you put it in gear with the motor in a tank. I rechecked everything twice looking for an air leak. All checked fine. Started looking at timing, found idle timing to be 16 to 17 degrees BTDC. Set the .464 mark with dial indicator and adjusted the pointer, it was out about 2 degrees. started the motor and tried to adjust the timing at idle in fwd gear to the book spec of 2 degrees. I got it to 4 degrees (I was running out of adjustment). Now it will start when cold (Idel is down to 1000 rpm now) and go into gear but restarting is a bear and it's hit or miss on dying when trying to advance throttle. Compression on all cylinders is good 125 - 130 psi. Anyone have any ideas? Thanks
