I am new to outboard motors and boating in general, I bought a bass boat with an 81 evinrude 50hp electric start motor on it...took it the lake a couple of times and it ran great...last weekend motor would start and run but would die as soon as it went into gear...after doing quite a bit of searching thru the forum I am compiling a list of things to look at on the motor and it won't die when the ignition switch is turned off
buy manual
rebuild carbs
adjust idle rpm
check compression
replace spark plugs (done)
replace fuel line and primer bulb (done)
after reading several of the threads on the forum this is what I have come up with if anyone has anything else to suggest I am all ears
buy manual
rebuild carbs
adjust idle rpm
check compression
