designcoup
- Sep 20, 2010
- 4
I have taken off the central deck section of a 70s Lucraft runabout. The stringers and foam seem okay. I have left a lip edge to keep the project manageable (did not want to remove flotation box-beam that follows the hull joint).
I plan to use epoxy resin and marine ply. My questions are around the specifics:
1. How should I seal the plywood prior to installation?
2. Should I screw in the plywood or bed in epoxy/filler?
3. Is there value in removing old foam if it seems okay? Or adding mix-in foam?
4. What layers/weight of epoxy resin/cloth do you recommend for the top? I plan to use US Composites resin and cloth.
5. Finally, the cause of the problem was leaking water through poorly mounted seats. The bilge channel was full of water with nowhere to go. Should I drill a hole into the splash well to drain this channel?
Thanks for your support,
Bruce M
Atlanta
Bruce M
Atlanta
