conchboater
- Sep 25, 2010
- 5
I have a rebuilt 1994 115 Johnson. I normally run it almost every day. It set up for several months after I had surgery. It started hesitating and running terribly. It would idle out the canal but would not get over 2000rpm without bogging and quitting. I rebuilt the carbs. I think someone put a new fuel line in previously without a water separator in-line. It now idles great but still hesitates at 2500rpm and sometimes will get up on a plane but rpm's will fluctuate up and down slightly like surging in and out. How should I expect it to run if there is water in the gas? I plan to put in a water separator this weekend. Is there anything else that would be causing it to run so poorly?
