I have a 1988 alpha one and it runs great but the trim indicator on the dash doesn't work. Is there a quick and dirty way of testing this system. Any common problems that would cause this condition. <br /><br />Thanks in advance.
Use this guide to test your gauge. <br /><br /> http://www.tflx.com/pdf/GAUWORK.pdf <br /><br />If the Gauge works you have now narrowed the problem to the wiring from the gauage to your engine, then your engine to the transducer, then the tranducer itself. You can test the trandicer by putting an ohm meter on the transducer, losen it up and move it and look for the resisantce to change w/in the expected range shown in the guide above.
