Hi guys,
I finally tank tested my newly purchased 1976, 70HP. It ran good with pee-hole mod installed. Problem is...only the temp guage worked and I am fairly sure the other guages are wired correctly....The Tach and Amp guage had no response. The Tach guage may be bad but I doubt if both are. I put a meter on the battery before running the motor and during...Both readings were 12.6v. The Amp guage stays at zero, on or off. I don't think the motor is charging the battery. Rectifier? Stator? Would this affect the RPM guage? The other question may be a long shot but...the service manual says timing is 17 BTDC at 5500?? How do you check at WOT?? I can rev it I guess when I get my tach to work but...is there a way to rev in nuetral?? I checked the control box pretty good and do not see a way to rev the engine in nuetral?? Any help much appreciated
