Re: Chaparral 300 with twin 5.0Gi and SX
An Alpha One is the simplest drive out there. It uses a dog clutch (which is to say that it just clunks into gear) in the lower unit of the drive. All VPs and all Mercruiser Bravo Searies have a cone clutch, that shifts in the upper unit of the outdrive. They shift smoother and can handle more weight and power.
So a VP SX drive is like a Bravo 1. Good all around drive. Bravo 2 was specifically aimed at "BIG OL' HEAVY CRUISERS". Large diameter props = equal lots of blade surface = lots of prop thrust to get the big boats moving. It has fallen out of favor in the past 10 years due to the Bravo 3. The Bravo 3 has the counter rotating propellers, like a VP DuoProp (DP for short). It does most all things better than a single prop outdrive. It's just a lot more expensive to buy, and propset changes are even higher priced ($1200+ for brand new props, $600 for used on Ebay, maybe a little less, if you're lucky), with much more limited options.
You will not "easily" cruise at 33mph loaded in the boat you described. Most boats in that size range "cruise" in the mid to upper 20s. And that's not a bad thing.
