prop selection
c21fishing
i have a 1989 70hp evinrude model e70tlcem i currently have a 13 3/8 x 17 prop on it i am looking to get a 13 3/8 x 19prop but i cant find on that is 13 3/8 any suggestions . thanks
tashasdaddy
Re: prop selection
better help if you posted in the prop forum.
Haffiman
Re: prop selection
Do not worry too much about the dia.
The newer BRP props are 14 and not 13 3/4 as the old ones, but they fit.
Blade geometry however is slightly different and as a total a bit 'heavier' than the old ones.
Responds better to trim, but less stern lift.
If not replacing a prop with the exact same type and shape as the old one, always do a test run before final buy.
Any DECENT prop dealer will assist you with that.
