wetbehindtheears
- Sep 13, 2010
- 5
I am changing the old prop on my 87 regal 18' open bow. I was in the boat for the first time and I may have hit a log or something in the water but the belts on the 4.3 smoked and the engine revved out. The next thing I know the boat does not move. The engine runs and when I got it out of the water I was told the "jets" may be clogged. Well I hooked up the "ears" and flushed it, the boat goes into gear and the prop spins well in both directions, I was told i spun the hub. I did the test of marking the hub and prop but while I was installing prop back on the shaft it spun. The marks were a little out of line. I just want to make sure I am not having my leg pulled. I was told that if the boat goes in gear and the prop spins I have not torn the coupler. I will be doing the right thing by replacing the prop and hub. I know the belts on the engine smoked because they are glossy now. does this sound right?
