baycruiser
- Sep 17, 2009
- 16
I have a 1995 5.7 Mercruiser with a 4 barrel carb and a Alpha One outdrive. I have just bought a reman long block and installed it in the boat. The engine starts right away, but idles at 1100 rpm and within a few minutes loads up with fuel and will choke out unless reved up to burn off fuel. As far as I know at idle fuel should only be delivered by the metering rods not from the top. this was an existing problem before but not as bad. Thanks for any suggestions.
