Hey Guys,
Ok, so I have a 2010 ALumacrraft 165CS (16.5') with a 60 hp Merc 4 stroke and all told, the boat weighs in the neighborhood of 1350 pounds with all gear plus I usually carry 3 adults.
The stock prop was a merc 10.38 x 13 aluminum and although it would pull 5800 rpm at WOT (GPS) with 3 guys, it has a lot of slip and was kinda doggy in general. So I decide to try a Solas Amita 4 blade 10.5 x 13 and although I love the prop - it is SMOOTH - it is still doggy out of the hole and I can only get 5300 at WOT (at 30mph). I need to be closer to 5800 at WOT and I would assume that might help my hole shot. My boat is heavy as I have it set up and with one or two guys its great...3...it's just ok. I really want to get on plane better and I am not so concerned about top end. The boat is less than a year old and runs perfect.
What prop would you recommend at this point with all else being equal? Should I go 12" pitch 4 blade (Solas) or maybe a SS 3 blade 12"?? I would welcome a suggestion cause I am frustrated at this point!
