Starter does not always engage the flywheel
mattsmall1972
I have noticed that my 1989 Evinrude 35hp outboard does not always engage the flywheel when attempting to start the engine. However, the starter always turns. Could this be a symptom of a less-than-charged battery? I've searched the forums and seen that the "bendix" might need to be cleaned - are there any instructions on how to do that? Any other ideas are appreciated.
Thank you
Joe Reeves
Re: Starter does not always engage the flywheel
A charged battery is a must.
Clean all cable/wire terminals and the components they attach to that relate to the electric starting system/circuit.
If grease/oil exists on the bendix assembly, that collects dirt, dirt creates binding, binding keeps the bendix from rising properly. Clean the bendix assembly with a brush and WD-40, then blow it off with pressurized air if a compressor is available.
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay auction at:
http://shop.ebay.com/Joe_OMC32/m.html?_dmd=1&_ipg=50&_sop=12&_rdc=1
