Re: 1977 Mercruiser 120 hp I/O
I am the original owner of a '67 Sea Ray IO with the 153 cu.in. 120 hp mercruiser engine. This boat and engine has been very reliable for 43 years. The interior, seats, guages and components are still in excellent condition. The engine has has some routine maintenance over the years but runs great. I have replaced intake/exhause manifold gaskets twice, lifter cover gasket once, fuel pump once, water pump and gasket once, water pump/alternator belt once and rebuilt the carb at least 5 times. I did all this by myself and saved a ton of money. The lower unit water pump, steering cables, and outdrive gears have been replaced over the years by a tech. The engine is truly a remarkable engine made by Chevy and modified by Mercruiser. I think it is sometimes referred as the "IRON DUKE". The only issue that is sometimes annoying is the ignition. After a hard run and subsequent shut down, the engine may not start w/o lifting the cold start lever. This could be fuel percolation due to hot soak or something else since the engine is not ventilated like a car. If the previous owner maintained this engine and outdrive like I have, I would say you should a good boat.
