So I have a 1990 48 spl. I just soaked the carbs and cleaned them really well and got it all back together and runs great on muffs and also idling at the dock. Finally took it out to run it and it will not make full power. I can go full throttle and push the key choke in and then it will run awesome. While we were out there I noticed that the top Carb was sweating like crazy. The bottom one wasn't. We assumed that the top carb was the problem so we tried to make an adjustment with the needle valve and it didn't matter if it was all the way out or all the way in. I am at a loss. It idles just fine and runs great unless its at full throttle. I could really use some help here fellas....
