Hello all...trying to figure out what this motor is trying to tell me.
It's a 1991 V6 150HP (edit...titled as 1991, actually 1990 E150STLESB from what I can find), VRO has been removed, running pre-mix.
New controls with the Johnsonrude adapter to allow use on the older motor.
It's been running fine for a while now, but this weekend it started giving a "beee beee beee beee" after a few minutes of running. The beep varies with the motor speed. I checked and the brown (tan?) wire that I THINK is the VRO warning sensor is un-plugged. For testing I remvoed the wires that connect to the head in a potted epoxy spot near the top of each bank. I assume these are the temp sensors. No change. Then I noticed a "T" the main fuel line that runs to a sensor with some wiring. Guessing this is a fuel pressure sensor? I disconnected it and tested, again no change.
I'm lost trying to figure out what this warning is. I have found several posts concerning "normal warnings". Steady tone = overheat, beep every 1 (some say 2??) seconds = no oil; beep every 20 seconds = low oil. No luck on the "audio tachometer" (ha ha ha) beep.
Thanks for any input!
