I have a 1973 Johnson 85 HP
I want to wire a tachometer and voltage guage off the ignition switch.
I already blew one fuse...so guess it is time to ask for some help before I do some real damage.
The remote control has a ground screw labeled "Tachometer Ground".
Can I run a ground wire from the tachometer ground screw in the remote control the tach, and then to the voltage guage?
I am not planning to use the fuse panel...all the accessories are run through the fuse panel and attached to the deep cell battery. Should I wire in a fuse between the ignition and the tach?
In words, here is what I am trying to do...should this work?
Positive = Ignition to Tachometer to Voltage guage
Ground = Ground screw on remote control to tachometer to voltage guage
Thanks
Thanks
