DamianJP
- Mar 25, 2008
- 605
Hello again
My nephew had this engine for 4-5 years and used in salt daily. It has these bad symptoms.
A)Stops peeing now and again and then just steam followed by the overheat alarm. Have to rev it abit to get the pee stream back and alarm goes off.
B) Tries to Idle and eventually chokes it self out with it's own exhaust. Take cover off and it will Idle all day long.
Sounds like to me that the gasket and/or plate between the powerhead and the mid section seems like it has succumb to the salt and it letting the exhaust into the cooling area and vise/versa. The area between the powerhead and the mid section is visibly leaking exhaust/water from the crease.
1)Is there anyway I can get a Compression reading and test the engine to see if it worth to fix this engine? Wouldn't the head gasket be giving me a low reading when it"s compromised?
2)Can the gaskets on the water jacket on the back 2 cylinder banks be letting exhaust into the cooling area too? They don't leak any water though.
If I test this engine and it's worth to fix this problem, I'm going to need help and some tips on what to replace while I'm in this area, and how to get the powerhead off and the steps that follow. Im going to get him to get a manual too but I have never done this before and real life experience/trial and error experience will help me out BIG time.
Other than carbs seem clean and good and cooling stuff(Therms,Poppit,Pump) seems fine but im going to probably replace the cooling stuff after I get done with powerhead. They probably took a beating with this other issue. Power head was recently rebuilt before my nephew bought the boat so if everything checks out I think this engine has some life left in her. Also the oil pump plastic gear seems like the teeth didn't round off or is bad, we never get a oil alarm just a heat one.
I know I'm rambling abit but I really want to get this done for my nephew. He works his balls off making money with this boat daily. He knows I love learning and working with engines (Mainly outboards) so he came to me with this request and I told him iboats will give us the straight skinny on things. I'm excited about this and I hope we get the green light from you 'guys' to do this work. It will be fun to work with him and learn together!
Thanks,
DamianJP
PS: My dads '77 55hp Evinrude has this same problem and is waiting for me. This will be GREAT practice even though they are two different beasts.
Thanks,
DamianJP
