I have a Johnson 60hp 1990 outboard. When i get to quarter throttle its like a rev limiter cuts in and the motor cut in and out. I put a rpm gauge on and it starts screwing up at approximately 3000rpm. Here's the list of things i have tried - cleaned carbs 5 times, compression test, tested and replaced stator, new ignition coils, new power pack, new spark plug wires, new top crank seal, set the timing, tested fuel pump, drop down test, took bottom leg off checked bottom crank seal, new plugs of course, checked wiring harness--- if anyone has an idea for me to try next please let me know Thanks
