motor dies like you turned key switch off? i have checked high pressure fuel pump when it would die the fuel pressure droped to 0# but still had fire to the pump so i bought a new high pres pump worked good first time took it out 2nd time same thing always starts back up after it dies will run all day at 50mph but between 57 and 72mph chugs 2 times and like you turned the switch off no signs of fuel leaking from low pres pumps and the fuel fielter on the motor is clear and 3/4 full help please
