I have a 1983 johnson 15 hp seahorse shortshaft. I am experiencing problems with the throttle mechanism. the handle will rotate but it is not advancing the throttle down inside the case on the left side where the shaft enters the case something is slipping. If I apply a small amount of pressure it will increase rpm slightly, and it will lock the shifter, enough that I have to rotate it back in order to shift it. does anyone have a blowup veiw of the thottle linkages so I can figure out where the slippage is occuring? Thanks for the support 15johnson.
