Re: firdg. Question
Re: firdg. Question
My 1974 camper still has it's original 3-way fridge. It gets used only a few times a year and still works great.
Your fridge in your camper works a bit differently than a regular electric type fridge, your is an ammonia absorption system, when all of the warm air in the fridge is absorbed there is nothing left but cold..
The coils are filled with an ammonia solution, that actually absorbs heat instead of a compressor that blows cold, it is three way, in other words, gas/propane, electric and 12volt, but it still heats the coils causing it to absorb the heat in the box. There is a heating element in the chimney that runs off of electric and there is a heating element that runs off of 12v. If the coils ever go bad, you will know it right away, because it will make your eyes burn when you open it up!
We used to turn them on their side, if they would not cool down properly, due to the fact the ammonia would crystallize in the coils and turning them on their side would mix the solution and kick them in the butt to start working again and allow the solution to circulate in the coils.
As others have said, I would not recommend turning a compressor system on its side, it could cause problems in the compressor...
I normally leave our house fridge/freezer running in the winter, when we leave for a couple of months and have never had any problems, but if unsure, just unplug it, it is no different than cutting the power or even when you purchased it new, when you buy them new they normally have not been plugged in for months, unless it is a floor model..
Also if you empty it and leave it running, and the door seals are good, it will actually run very little, because the door won't be opening and closing,, and you won't have anything in it to cool off..
