gtdavis
- Apr 23, 2010
- 78
Ok I already typed this once gonna try again..... Was out on the water today running about 35mph started hearing a rapid sputter / spitting puffing??? sound None of the guages were affected good temp, oil pressure ect....slowed down and went to a safe area to check it out...went back to open the box actually couldnt hear it as well opened the box I noticed about 3 tbsp of oil in the bilge and some faint light smoke comming from the base of the valve cover?? somewhere around the carb... So I thought maybe a gasket failing. Figured Id watch the guages and limp back as I was still a long way out I got about two miles down and the boat shut down dead in the water. As first I thought it seized but I could jump it at the solenoid and it would turn over fine but wouldnt start....checked all the wiring around the motor and everything looked ok...I went back to the front and turned the key to on (not start) and the motor tried to turn over??? Looked under the dash and the wires going to the ignition switch were very hot and the casing on the purple wire was melting.... Figured at that point i was lost and figured wasnt anything I was going to fix on the water even if I did know what it was so I disconnected the battery and called a tow. A side note I noticed the RPM gauge was stuck like the boat was still running and this morning I had to tap the volt meter to get it to read?? Thanks in adance!
