Re: 1983 175 Johnson
What he said.
There's been some give and take about how readily the TCW3 oil mixes in the tank. Stories about people filling the tank, then just dumping a lot of oil in afterward and expecting it to mix magically - and it settles to the bottom and can get sucked up by the fuel pick up before it gets a chance to mix well.
Some say it just mixes, don't worry about it.
What I always did is pour the oil in an empty tank and pump the gas, splashing it around to mix it up. Or if the tank was partially full to begin with, I poured the oil in along with the flow of the first couple of gallons of gas as I was pumping it in to get it mixed up.
Some people premix a small can of gas with all the oil they need (in other words, it would be very concentrated, but mixed), put it in the tank and then fill the tank with raw gas to get the proper mix.
You can buy containers that have ready to go markings for how much oil is needed for various amounts of 50:1 mix.
It's really not a big deal, but I prefer VRO because it's better and more reliable than me, and much more efficient.
