Ok so I took the boat out for one last weekend on table rock and a weird problem popped up. First of all the carbs where just rebuilt at the shop so I don't think they are the issue also the fuel line was replaced as well with an attwood replacement. Now the problem is the motor surges but not all the time and only at WOT. Sometimes if I was to shut it off and turn it back on the problem would go away and other times I would have to pump it manually a few times before it would go away. At other times it would run just fine all day with no issues. I suspect the fuel pump needs rebuilt, but it almost acted like something was clogging the fuel pickup in the tank intermittently. What would be your first choice as the problem? Also what size fuel lines am I supposed to have?
