Recently purchased this boat and on the first time out noticed water in the bilge.When I pulled the boat found oil/water mix coming out of drive bellow.Removed upper gear box and found hole in bellow.The seal behind the main shaft bearing is junk(u-joint yoke seal)so water got into the bearing.Is this supposed to be a sealed bearing?I didn't see any way to get lubrication to it.Will I have to yank the engine to change it?
