Hi all - new boy here and wondering if anyone can help please.
Went out at the weekend and after a 10 minute 5 knt ride from the slipway to the sea entrance I gave the helm to my wife so I could sort out a couple of bits and as soon as she put it in gear it died. Re-started it 5/6 times - each time the same - into gear...dead. Would rev OK in neutral though and no coughing/spluttering.
So..got a tow in and while doing this I re-started it* and this time into gear it was OK, repeated a couple of times and still OK.
*(Hard to remember in the heat of the moment but I may have tried to move the fuel changeover switch at this point).
Moored up and the v. helpful boatyard guy suspected the in-gear/no-start safety circuit. Of course it behaved perfectly this time - so, we headed up the channel and it was fine but one last try and again it died. This time with spluttering (fuel?)
I believe this was because we had the changeover switch wrongly set and on the nearly empty tank (twin tank set-up).
Changed over tank and then went out - did an hours blasting and came back no more problems.
So.... are the two issues un-connected or would the fuel running out somehow allow the engine to rev but die instantly when put in gear.
Just not sure if the 'into gear' cutting out has any connection to the 'fuel spluttering' cutting out...the spluttering cut out seems to be a fuel issue but the into gear and cut seemed instant like an electrical issue. It was not: into gear, then rev then cut but virtually instant into gear and dead. Plus it would happily rev cleanly on the throttle lever rev control.
Thanks all for any advice.
