Hey all, after my first sucessfull trip to the 1000 islands NY with my 69 mark twain with rebuilt mercruiser 140, I experienced a blown hydrolic tilt hose on my outdrive.
I attempted to raise the engine and when it wouldnt give, i noticed that the hydrolic fluid was leaking from the hose, and it sounded as if the pump was dry. To avoid killing the pump I got it out of the water without scratching skiff and took the pin out of the part that attaches the hydrolic arms to the lower unit. Raised the engine, propped it, strapped it to the trailer and was able to get her home.
The line runs all the way into the lower unit and to the pump next to the engine, has anyone ever done this? Is it something I can do? I know the gimbal housing needs to be taken off not sure what that will entail, and i imagine running that hose wont be easy either. Can I get the part anywhere online?
Im just trying to weigh my options out with only so much time left in the season I want to get the boat back into the water ASAP.
I attached a picture, note that it is the hose closer to the transom and I attempted to remove it, thats why its not screwed in all the way, I also attempted a tape job to try and raise it, that also failed.
Thanks in advance.
Thanks in advance.
